00 Silverado Z71, LQ9 w/ LS3 heads, BTR cam, Whipple 2.9@8#, 4l80E
Depending on the size of the holes you drilled in the trans plate the TransGo kit should give you hard fast shifts for sure .
I did the middle sized holes and the trans shifted very hard and fast with stock trans parameters , there was no need to adjust from the stock settings .
All three holes were enlarged as pointed out in the kit instructions .
Let me put it this way , 1-2 shift would put down marks and felt like someone hit the rear bumper with a car .
2006 Trailblazer
You can try several things:
- set the Throttle Kickdown tables to all 100% in all cells (otherwise they can interefere with PT and WOT shifting);
- swap the two shift solenoids with each other.
+1 what Chevy366 said above.
If they are GM/Delco solenoids, you won't be able to switch them.
Im watching this thread because mine just recently started doing the exact same thing... shifting like mush. And you got the exact same setup I do.
