Results 1 to 5 of 5
Thread: Fuel trims in Lean Cruise
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default Fuel trims in Lean Cruise
    I had been seeing ltft showing up during lc and I wasn't sure if they were actually affecting the mixture or if the computer was just ignoring the fuel trims. Tonight I logged a stretch of road and attached are the logs. I filtered both logs and compared the bens of each log with each other. Let me know what you guys think. Its less than a 5% difference but to me it seems like there is a correlation.
    in each log i started ate the startpoint and drove, then turned around and came back to the starting position.
Name:	With fuel trims dissabled.png
Name:	With positive fuel trims.png
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Oct 2006
    LTFT should still show in the log, but since you are not in Closed loop for lean cruise the fuelling would not be affected by O2 sensor feedback.
    I do not have Efilive on this computer, but will take the logs home to have a look.
    The Tremor at AIR
    Aug 2010
    Hi Greg,
    Great idea for an experiment. As many already know, there are no STFT while in LC (logs will show 0) - the PCM runs in OL directly from the VE table. But your question - do the preexisting LTFT stored in the PCM memory impact (in anyway) on the final fueling while in LC - is not something I have ever looked into.
    When the difference in the results are less than 5% from a road course test - it is difficult to infer causality. Someone with a chassis dyno and an inquisitive mind could probably settle this question.
    Regards,
    Taz
    Oct 2006
    My observations is the LC uses it own tables and LTFT has no impact on it .
    2006 Trailblazer
    Dec 2010
    My Wide Band O2 sensor also shows no LTFT effect during Lean Cruise.
  1. Rich trims at idle but cruise is fine 1997 corvette
    Last Post: November 10th, 2010, 04:52 AM
  2. Lean Cruise help
    By Manbearpig in forum Gen III V8 Specific
    Last Post: March 7th, 2010, 02:38 PM
  3. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  4. RR Lean cruise?
    By BRD-PREY in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 11th, 2009, 06:31 PM
  5. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
