Results 1 to 3 of 3
Thread: Convert mm3/stroke to mm3/second
    Oct 2011
    Default Convert mm3/stroke to mm3/second
    Is there a formula/method to convert mm3/stroke to mm3/second? More specifically I am trying to understand the relationship between tables B1001 and B1010.
    Thanks in advance.
    Mar 2009
    B1001 is simply your desired rail pressure you want teh CP3 to try and hold. it then uses actual rail pressure to figure pulsewidth. As for B1010, that is a tough one to figure out. There is no real way to figure it out dead on as that flow data also must account for returned fuel to the tank, not just fuel that teh injectors flow into the cylinder. The common rail injector works as a differential valve. It opens a small bypass port which causes a pressure drop at the seat which opens the plunger. When teh small bypass valve is closed the pressure differential is gone and the plunger closes. Also in a perfect world teh injectors will return no fuel when they are closed, but in reality they all will bypass some. This bypassed fuel also must be accounted for in the total flow figures. This is why there are variable built into the table as to how far the current can stray from desired. So to put it simply, no there is no easy way to figure total fuel flow of the CP3 system. As for how I set B1010, if the rail pressure at idle is to high and it cannot lower itself enough to hold desired, you raise the value of teh first 2 cells and smooth the 3rd to match. If it is to low you lower the value. And I zero out the last 2 cells to try and help it hold rail pressur better when I stab the throttle WOT.
    Jan 2006
    I have wondered about the origin of that scale also. Thanks for the clarification in what you have seen with it.
    Custom Tuning Services
  1. 120 mm3
    By robof16 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 23rd, 2011, 09:58 AM
  2. No mm3 (fuel delivery per stroke)????
    Last Post: October 30th, 2011, 12:46 PM
  3. MM3 vs. PW?
    By mstordahl in forum Cummins 5.9L
    Last Post: October 26th, 2011, 12:23 AM
  4. How many MM3's can you command?
    By LBZoom in forum Duramax LB7
    Last Post: February 2nd, 2010, 12:15 PM
  5. Boost tables - mm3 per stroke?
    By turbo lcc in forum General (Diesel)
    Last Post: March 14th, 2006, 03:03 PM
