Results 1 to 7 of 7
Thread: cant change vin# after flashing different tune.
    Oct 2009
    Default cant change vin# after flashing different tune.
    Today I was gonna try to get my stock tune of my truck for the first time, after trying it for a few times it didnt wanna work giving me the $0311 code, after doing some research I found out that the Smarty leaves a footprint behind after setting it back to stock. So I read some more long story short, I uploaded a stock tune from one of my other trucks that worked fine and full flashed this tune into the truck that I was having problems with, Then I read on the web you can change to vin# to match with the truck, after numerous tries its a big no no, as soon I try to upload the new vin its giving me the $80 code, and truck wont start.
    What can I do here to fix this problem Thanks in advance!
    Jul 2004
    Are you using the Scan tool to try and change the VIN?
    Ira
    Oct 2009
    Yes I was, using the shift+ctrl+f9 key
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Make sure your V2 is up to date. Then try restarting your computer. Open scan tool and connect to CMB 5.9. Click the program vin button and make sure your vin # is correct in the bottom line. Hit reprogram and it should work.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Oct 2009
    Everything is up to date as far as I can tell but I use the generic can ECM controller at my scan tool is this the wrong one? Maybe I am missing an up date.
    Yes thats your problem, you need to select the CMB Cummins controller then change the VIN using what DDP said.
    Oct 2009
    Yes It worked!, I knew I had the latest updates but i just downloaded it again and restarted the laptop a few times and boom there was the CMB controller and changed the vin with no problem! Thank you guys!
  1. Allison VIN flashing
    By MaxPF in forum Allison 5 & 6 Speed
    Last Post: January 11th, 2019, 08:58 AM
  2. VIN Change
    By chrleb2 in forum Cummins 5.9L
    Last Post: June 16th, 2011, 11:38 PM
  3. Replies: 1
    Last Post: May 14th, 2009, 09:17 AM
  4. cant change VIN
    By Samdogmx in forum Vortec V6/V8 Specific
    Last Post: November 12th, 2007, 11:35 PM
  5. vin change
    By 69camaro5speed in forum Vortec V6/V8 Specific
    Last Post: January 24th, 2007, 01:08 AM
