Results 1 to 5 of 5
Thread: Tuning '03 suburban with procharger
    Dec 2005
    Default Tuning '03 suburban with procharger
    just a few questions.
    1. truck has stock injectors, should I get lucas 42lb'ers or run stock and check duty cycle and afr
    procharger kit is 7-9 lbs
    truck has a rising rate FPR, has no KR, but is running lean
    have not checked with wideband but narrowbands are only getting to 850
    I have an LC-1 and will begin tuning next week
    2. Is this the correct path for tuning?
    a. injector flow rate(if not using stock injectors)
    b. idle tune (if running cam with unstable idle)
    c. autotune VE table
    d. power enrichment tuning
    e. MAF calibration (if still running maf)
    3. when does the vehicle enter PE mode?
    I looked at the parameters under mixture but it doesnt tell me when PE is operating.
    4. should I upgrade to 2 bar map sensor and custom OS to run 7-9 lbs?
    would this be easier to tune with?
    5. after I reset LTFT's, how much driving is required to see the results?
    are reccomended LTFT's different for a boosted vehicle?
    TIA for any help
    Quote Originally Posted by Chunx
    TIA for any help
    A few quick points.
    LTFT's are useless as an indicator to actual mixtures under boost, a normal O2 sensor will not know the difference between 9:1AFR and 13.0:1 AFR.
    I think with 7-9psi you will need to go to a 2bar sensor and ditch the MAF.
    We have a tutorial on how to do this.
    As for PE mode, if you ran with our 2/3bar PCM Operating System then PE mode can be ignored, you can command any AFR at any MAP / RPM you want without worrying about the PCM dropping out of PE mode in boost.
    I am not sure how to setup the Injector/VE tables with a rising reg, others may know?.
    Ross,
    With the custom os for 2/3 bar operation, wouldn't it be worth it to ditch the RRFR and just make adjustments through raw tuning?
    I never liked the FMU's that come with most kits but understand that are they because the kits are designed based upon no tuning capability. Since we have control over fueling under boost much better these days, I don't use them.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Dec 2005
    The regulator came with the kit, I dont think I will use it.
    even though the afr didnt look bad after minor PE adjustments
    but the 150% duty cycle is REALLY scary
    I ordered some 60# shorty injectors and they were too short.
    so now I will have use the long ones with spacers on the fuel rails.
    what is the part number on a 2 bar map sensor?
    I looked in the tutorial and could not find it.
    Dec 2005
    NM
    the answer is a couple posts below this one
  1. 5.3 Suburban w/22's
    By horsehaulin in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 11:21 AM
  2. 0411PCM Suburban 4x4???
    By hquick in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 27th, 2007, 08:26 AM
  3. 07 suburban
    Last Post: August 5th, 2006, 03:03 AM
  4. 1st ve autotune of procharged suburban
    By Chunx in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2006, 01:53 AM
  5. Tuning '03 suburban with procharger, 1 bar
    Last Post: January 24th, 2006, 11:37 AM
