Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: AutoVE tuning with turbo
  1. #41
    Senior Member WicketMike's Avatar
    Nov 2003
    ttttt
  2. #42
    Member bK's Avatar
    Mar 2004
    Quote Originally Posted by Flyer
    I did a log on a Forced Induction car today that was tuned with Vcmsuite. When logging its MAP only went as high as 105 and all values below it seemed to be normal values at that rpm and speed etc.
    Did i use the wrong pid?
    The car has heaps of power - logged up to 1.36g/cylinder at 6000rpm
    I did the same thing last night with a friends car, logging SAE.MAP it only recorded 105kPa. I recorded GM.MAP Voltage which was 2.5V and recorded MAP of 105kPa. The voltage peaked at 4.0V during a logged run but stayed at 105kPa
    It's a 2bar MAP sensor, the car was programmed with HP Tuners with Custom O.S.
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
  3. #43
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Can someone make comment on this last post??
  4. #44
    Oct 2004
    Shouln't SAE.MAP be logged, not GM.MAP?
    Andrew
    EFILive Crew
  5. #45
    Member bK's Avatar
    Mar 2004
    Quote Originally Posted by Tordne
    I've logged both, i hope this screenshot will give you a better idea, you can see SAE.MAP stops at 105kPa but the GM.MAP Voltage keeps climbing up.
    Chassis by Holden
    Engine by Chev
    Cam by Comp Cams
  6. #46
    Member bK's Avatar
    Mar 2004
    I found the answer in all places in the "Custom OS Upgrade Tutorial.pdf"
    Configuring a 2 or 3-bar MAP sensor
    When the key is on but the engine is not running, the MAP sensor reads the barometric air pressure, usually 101kPa (14.7psi). When tuning in high altitude areas it is worthwhile reading the MAP values (using EFILive’s Scan Tool) at key-on with the standard 1-bar sensor to obtain the barometric pressure at the current altitude.
    After fitting your 2 or 3-bar MAP sensor, you must rescale the MAP sensor.
    Engine Diagnostics->MAP->Parameters
    • {C6301} MAP Sensor Scaler: 2-bar sensor: 190 3-bar sensor: 288
    These values will get the MAP scaler’s value close to what it needs to be, you will then need to adjust it (by small amounts) until the MAP sensor reads the same barometric pressure that your standard 1-bar sensor was reading at key-on, engine-off.
    Logging boost levels in the Scan Tool must be performed with the PID ‘SAE.MAP’.
    Chassis by Holden
    Engine by Chev
    Cam by Comp Cams
  1. AutoVE for turbo
    By BoostedLS1 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 30th, 2009, 07:09 PM
  2. Turbo Tuning Help
    By jckleewein in forum General (Diesel)
    Last Post: August 30th, 2009, 06:11 PM
  3. sts turbo tuning
    By xAustin in forum Vortec V6/V8 Specific
    Last Post: September 6th, 2007, 07:39 PM
  4. Turbo Tuning
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 07:43 PM
  5. Turbo & Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2005, 02:55 AM
