Have an 06 Chevy here that had a Quadzilla D/L and wanted EFI live DSP5. I got a dsp5 tune and a switch from a experienced tuner since im new to EFI live and Im told and lbz is a little tougher to tune than the older trucks. I licensed the ecm and full flashed it. took it a spin and It blows tons of smoke, no boost. reflashed the stock programming in and it does the same, ive logged it, looked at it, sent it to the orig writer of the tune, nothing. I bought a new ecm, swapped it in did a vats relearn, and started it and revved it a little and it seemed fine. so I copied the tables from the orig dsp5 into the new o/s and full flashed. took the truck a drive and it ran great for about 3 mi. same problem. no boost, pouring black smoke. came back and flashed in the stock program. again, no boost, black smoke. Im at witts end, If been through 250 bucks of dsp programming, 2 ecms, and 2 licences and this thing is still not right. anyone have any suggestions? if i could get it back to stock id throw the quadzilla in it and send it on its way but I cant even get it to run with a stock program. Ive gotta get this running asap. thanks in advance.
