You looking at twins or single?
Dan's Diesel Performance
www.dansdieselperformance.com
Honestly, I dont like either one of those turbos.
Going to get a single and preferably one that bolts right up to the stock configuration, and I don't tow.
EFI Live - The Smarter way to tune!
2006 Ram 2500 4x4
We've had good luck with a 63/68 .83ar turbo and a better exhaust manifold. Spools awesome and supports 600hp or so.
What is the consensus on Stainless Diesel and Bullseye Power turbos? I've heard some good things about the BatMoWheels.
2006 Ram 2500 4x4
Nevermind about Bullseye, I see Stainless stocks their turbos. Any input on an S362/68 with a BatMoWheel, 14cm wastegated housing and .80ar? Or any other ideas on good streetable turbos that will keep my top end temps reasonable?
2006 Ram 2500 4x4
We sell Engineered Diesel Turbos. I don't believe in the Batmo wheels. We ran the 63/68 with stock injectors and made 558hp and 1,119ftlbs. It was a nice street turbo and towed well.
I'm about to install a Borg Warner S363 .88ar (T4 63/68/14-16cm) and a PDI 2nd gen T4 manifold.
As of now my truck is pretty much stock save for a few things. Built trans, mechanical lift pump, intake, 2nd gen T3 manifold, 5" exhaust.
I'll be installing the T4 manifold turbo combo before I install my 45% (90ish hp nozzles) and Arson 3 to get a good comparison.
I'm running SilverBullet's tuning right now too. Which is friggin' incredible with my built trans!!! I went to install my built trans and told Les I would like to have a good tune to try the trans before I left the shop and he appropriately sent me a "TransTester" tune...and good lord was it one! Made my trans builder raise his brow when he went to test stop-WOT conditions. "Wow, no smoke."
Anyhow, hopefully shortly I'll have some results of slapping a good manifold/turbo on a stock fueled truck and then some more with the minimal fueling upgrades.
-Andrew
06 LBZ, EFILive
Dan I sent an email out to Chris at ED on Friday but I suppose they're off for the weekend. Would you mind PMing me a quote on that 63/68 with the specs?
2006 Ram 2500 4x4
Sure can. Give me about half hour.
