Thread: vin changing- csp
    Jul 2011
    Default vin changing- csp
    I have had to change vin numbers in the past between me and a couple guys and try different tunes. Since it is recommended to flash tune then read it and change bidirectional function to new vin. How can my buddy and I run the same base tune and tweak indiviually if I can not read the file from the ecm. It is ok to just use the bidirectional funtion with out loading it on a vehicle first. I really want to learn more about the functioning of the capabilities of the tuning but need some guidance on many things if I can not figure them out. Thanks anybody.
    Aug 2011
    Really no need to read out just change vin in 7.5 tune tool . Or script your tunes and run script on there stock files read is more for your base tune of your truck unless i am missing something here.
    Tuning by Zack StarLite diesel
    Nov 2010
    OP wants to swap csp-5 tunes built between one truck and another?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jul 2011
    Yes Les that's what i want to do. with out copy and pasting every table. is there an easier way or can i just switch the vin the regular way.
    Nov 2010
    VIN change is the simplest
    Les Szmidt
    2007 5.9 Dodge Ram
    Jul 2011
    thanks les just didn't want to brain dead my ECM
  1. Changing the VIN Number
    By Behold in forum General
    Last Post: January 9th, 2016, 08:48 AM
  2. Changing VIN
    By derekf in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2005, 12:04 AM
  3. Vin Changing in Flashscan
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2005, 02:36 AM
