I want to be able to input the correct SVO 30 injector flow rates. I had the old table that thought the injectors were rates at 43.5psi not 40psi. So the numbers are out. I just compared the two sets of numbers and i need to input numbers for flow rates that are an even 1.0428 across the board larger.
If i do this how much will this effect my VE tables numbers. How much do i need to adjust them by?
Also is there anything else changing these will effect? Timing? will it hot different cells because of a change in the VE table?
Any help would be appreciated.
Steve
