Results 1 to 4 of 4
Thread: Commanded Fuel Pressure
    Oct 2011
    Default Commanded Fuel Pressure
    I was logging a 6.7 tonight and noticed some varying readings. When first logging the truck ran smooth and the balanced vs uncompensated rates were very close. 2nd log the truck would stumble right after a shift. Rates were almost consistently off by 15 units. Logged the truck again and it started slightly off then pretty much matched back up. No more stumbling. We never even shut the truck off in between logs. I was just messing around with different pids. What makes up the differences in these 2 readouts? Is it a sign of regen? Anybody else notice this?
    07.5 2500 Dodge Twin Turbos, Dual Pumps, Deleted, 100% over nozzles, Fletcher Bump Stick, and more goodies, Awaiting EFI Live Tuning
    05 2500 Chevy Duramax, EFI Live Tuned
    01 2500 Chevy Duramax, ZF6, EFI Live Tuned
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    I'm not fully understanding.. care to post the log?
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Oct 2011
    The logs are on my other computer so i will post them up this evening.
    Oct 2011
    Log files attached. #1 and #3 are normal and #2 is where the differences are. The pids available on all the logs change but you can watch the commanded fuel pressure, both balanced rates and uncompensated on all of them.
  1. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  2. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. AutoVE Commanded Fuel Question
    By SOMhaveit in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2007, 12:35 AM
  5. commanded air fuel
    By 69camaro5speed in forum General
    Last Post: March 11th, 2007, 12:37 PM
