Originally Posted by
Jim_PA
The last time I had throttle cracker disabled, I noticed that if I left off the gas while it was in gear and coasted that way for more than a few seconds, then pushed in the clutch, it would try to stall. I learned how to drive my car differently... If I coasted in gear for more than a split second and then pushed the clutch in, I'd bump the gas pedal so it would re-start the idle-down process (or whatever it was doing)
I think what was happening is that when off the throttle and in gear, it was trying to correct the idle speed by taking out all the air, then when actually pushing in the clutch, it was so restricted it would fall right down to a stall.
Have you ever run into this when not using the TC?
