I was wondering if it's possible to have several logs ran on one map to fill the useable areas used by the ECM ?
'07 5.9 Mega 3500
11.7 @ 118 / 8200lbs
Ty, the problem you'll have is you can only open the one log file at a time.
What you can do though is once you have a log and it's populated a map, you can export it to Excel.
Then you can open another log and export that.
Then just take the data and copy and paste it into one map.
ok, that works... thanks.
'07 5.9 Mega 3500
