Results 1 to 10 of 10
Thread: WOT shift points
    Jan 2012
    Default WOT shift points
    I logged a 0-100mph run last night. I have my 1-2 shift set at 6750 and the 2-3 set at 6600. But on the logs its showing a 1-2 shift at 6450 and a 2-3 at 6400. Am I missing something?
    My truck, 01 GMC Sierra C3, Heads, cam, intake, exhaust and a few other mods.
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    You will need to drop the shift MPH as well.
    Jan 2012
    how far down do they need to go. They are about 6-7 mph lower than where Im shifting at.
    You also need to set the Throttle Kickdown tables to 100% all across.
    Jan 2012
    Here is the tune and log. The 0-100 is about half way through the log.
    0-100.efitune.org.tu.tun
    Jan 2012
    Ok, I bumped the MPH table to where it was shifting at, set the kickdown to 100% across the board. Went for a drive, and its shifting higher, but still about 100rpm low on the 1-2 and 150 low on the 2-3.
    Lightly bump up both the WOT RPM shift and WOT MPH shift... then if you overshoot, bump one of them down a little.
    Jan 2012
    Just an update.
    Got the shift points and AFR straightened out.
    Went to the track last month. Was 75 out and a DA around 5500+. Loaded the org tune and ran a 14.4@96. Got back to the pits and loaded my updated tune and ran a 14.05@97. I bumped the shift points another 50rpm and ran a 14.00@97.5. Pretty happy considering the heat. AIT started in the 115+ at the start of the run making my max timing 22*. Need some cooler weather.
    Also, Im looking at doing a COS but I need the commercial version. I am using V1.2. Do I need to get the V1 Personal to the V1 Scan and tune?
    http://www.efilive.com/index.php?pag...mart&Itemid=54
    Andy
    Quote Originally Posted by andysc3 View Post
    Andy
    Yes.
    Jan 2012
    Awesome. Thanks.
  1. Replies: 20
    Last Post: June 27th, 2011, 05:24 PM
  2. 4L60E shift points
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 28th, 2010, 02:37 PM
  3. Little help with changing shift points
    By Tarkstoys in forum Allison 5 & 6 Speed
    Last Post: June 29th, 2009, 06:54 AM
  4. tuning shift points
    By hot-dog in forum Allison 5 & 6 Speed
    Last Post: February 28th, 2009, 08:03 PM
  5. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
