I'm having a little trouble with incorrect values showing up in my maps when running logs. I've been working with Rich on this and he helped with what he could.
I've replaced all the cal. files which works to see the correct values in the tables but, not the other stuff.
I completely removed everything and reinstalled it, I made all new maps, verified PIDs for the map. If I run a log though, I get some strange values.
Likely, it's something simple but, I've not been able to figure it out.
edit: FYI, my timing readings are 20* too high in maps and logs. They're not in the tables though.
