Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: Filtering DFCO Cells
  1. #11
    Quote Originally Posted by GMPX
    Government cars are Statesman's with LS1's in them!!, who cares when someone else pays!!.
    Yeah, the fat cats make sure to look after themselves at our expense.
  2. #12
    Jan 2005
    Until that bit can be located, I would say you need to devise a filter around all the DFCO enable/disable settings in your tune.
  3. #13
    It is my understanding that anytime the PCM is not commanding stoichiometry it is in open loop fuel mode. Have you tried logging open/closed loop mode to see if it corresponds with the frames where you believe DFCO to be active?
    Alternatively, there is another flag called "Fuel Learn" which I assume would be off when in DFCO - don't want the PCM adjusting fuel trims based on DFCO cells.
    Open/Closed loop and Fuel Learn are both in pid {GM.STATE05}
  4. #14
    Oct 2004
    Thanks Paul, I'll give that a look. When in DFCO the commanded AFR does not change so could not be used as a filter criteria (commaded will still be 14.7 for exacmpe but actualy WB02 will read 19.5+).
    I'll check out STATE05 and let ya know
    Andrew
    EFILive Crew
  5. #15
    Oct 2004
    Actually.. I'm running in Open Loop fuel mode all the time so learning will not be occuring at any point, either while DFCO is ative or not :(
    I'll still log STATE05 and see if this is infact the case.
    Andrew
    EFILive Crew
  6. #16
    Quote Originally Posted by TAQuickness
    DFCO state Bit has been located, we will add it in to the next update, it is actually in GM.STATE05 you just can't see it yet.
  7. #17
    Jan 2005
    Ask and you shall receive. This is great stuff guys!
  8. #18
    Rule the world, mate.
  9. #19
    Oct 2004
    That is some awesome news!!!
    I'm sure this will let me do exactly what I want
    Andrew
    EFILive Crew
  10. #20
    Oct 2004
    OK, now I have another question... How do you use part of a STATE PID in a filter?
    For example: STATE05 represents a number of different Boolean states and looking in the F9 (Data) tab you can see the STATE PID is expanded into a number of individual values.
    How does one use one of those values in a filter? I'm preparing for when the DFCO PID is available.
    Andrew
    EFILive Crew
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 03:34 PM
  2. AD filtering question?
    By 67SS509 in forum General
    Last Post: November 16th, 2009, 03:24 PM
  3. MAP cells all the same colour????
    Last Post: October 21st, 2008, 05:02 PM
  4. PLX WB reading 13.6-13.62 in all cells
    Last Post: May 19th, 2006, 04:16 PM
  5. Filtering Data
    By bink in forum General
    Last Post: August 13th, 2005, 12:35 PM
