Results 1 to 5 of 5
Thread: Ls2 knock sensors on a gen 3
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default Ls2 knock sensors on a gen 3
    Hey guys i'm wanting to swap over to ls2 knock sensors. I see that racetronics has a harness that plugs right into the factory harness. some people have said that they had problems tuning the computer to work with them. Has anyone here has any experiance doing this type of thing?
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Sep 2008
    Nobody?
    Stock for now
    Aug 2010
    Hello Greg,
    Sorry haven't had much time for the Forum lately. Controlling LS2 knock sensors with an LS1-B PCM is common in LS2 conversions that were originally equipped with the E40 ECM. In your case, you only have to deal with the knock sensors - not the LS2 TB, TAC, and APP.
    Set B1402 to "Flat Response LS2" - and follow the wiring instructions listed in the description. As far as configuring the knock sensors goes, you will have to merge some of current settings with those from a reasonable comparator (in weight) - like a 2006 LS2 Trailblazer SS.
    Taz
    Sep 2008
    Thanks Taz!
    Stock for now
    Feb 2008
    I used an extension harness to mount ls1 knock sensors to the side of the block in my l92 416. Haven't had an issue in over 5 years.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
  1. Gen 4 spark knock
    By nchristian in forum Gen IV V8 Specific
    Last Post: August 27th, 2009, 09:20 AM
  2. Tuning LS2 with LS1 knock sensors.
    By rally1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 20th, 2009, 02:30 PM
  3. LS2 motor with LS1 knock sensors?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2006, 05:46 PM
  4. LS1 knock sensors in C5 and LS2 block.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 05:15 AM
  5. LS2/LS7 Knock Sensors and LS1/6 PCM
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2005, 10:55 AM
