Results 1 to 3 of 3
Thread: 8.1L PCM Controlling 1991 to 93 4L80E
    Member 1BadAction's Avatar
    Mar 2009
    Default 8.1L PCM Controlling 1991 to 93 4L80E
    Is this possible? In other words, if I take an 8.1L power plant with it's PCM and swap it into an older 3/4 ton Suburban that originally came with a 4L80E, can that 8.1L PCM control the older 4L80E? Or will I need to swap something out in the transmission?
    2013 1SS/1LE Blue Ray Metallic Camaro - DD
    1991 2500 Suburban - Roller cam'd high compression 454ci BBC tow monster
    1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
    1984 18' Contender Tunnel/2.4 Merc ModVP
    Dec 2008
    It depends. If the 8.1L had a 4L80E behind, obviously yes. If the PCM had an Allison, but has the same OS number as a tune that had a 4L80E, then yes, do a segment swap. Also, if the 4L80E has the original style (91-92) internal harness, it will need to be updated. If its an 04+ PCM, will probably need an 04+ force motor in the 4L80E.
    Mar 2009
    Excellent, IF I do what I'm thinking, I want to make sure I start with the easiest engine/pcm to use. Sounds like up to an 03 is the way to go.
    I'm not sure if the harness has been done, but from what I understand it's a fairly simple procedure. Project TowBeast full steam ahead! lol
  1. 2002 PCM Red connector pin#51 Transmission Temp Signal 4L80E????'s
    By GAMEOVER in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 5th, 2011, 05:18 AM
  2. 0411 controlling the fans issue...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 06:50 AM
  3. Controlling Data Collection Rate
    By dinorex44 in forum FlashScan V2 BB Logging
    Last Post: May 13th, 2009, 06:11 PM
  4. Controlling idle timing.
    By Redline Motorsports in forum Gen IV V8 Specific
    Last Post: March 25th, 2007, 02:47 AM
  5. Controlling timing with 2 Bar OS?
    By Redline Motorsports in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 30th, 2006, 12:59 PM
