Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 56
Thread: 07-09 6.7L Feature Request List
  1. #41
    Quote Originally Posted by 4NEATR View Post
    The single biggest thing would probably be the tire size change, for guys who don't have annother tuner like my xrt, don't have the ability to get the speedo even close if they have EFI alone.
    Cheapest extended warranty there is. Adjust tire size so at 60 speedo reads 30. Easy to remember and doubles warranty. I don't need the speedo at all. Read my speed off the GPS system.
    Stealthy Dodge 07.5 2500 2wd with lots of torque multiplying assistance, and now EFI Live tuning.
  2. #42
    Apr 2012
    I know things are busy and there are more issues at hand now, but it would be great to get at least the options that the 5.9's have.
    2007.5 Dodge 3500 - some power mods with a 48re behind it
  3. #43
    Nov 2005
    Specifically what are you looking for?
    Cindy
  4. #44
    Oct 2011
    Where is inputting injector calibration numbers at these days ?
    I am really happy to see the CSP functionality getting out there.
  5. #45
    By Injector Calibration numbers, do you mean like what we have to do with the LMM how they are copied from the GPM to ECM?
  6. #46
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Default 07-09 6.7L Feature Request List
    Remember the 6 digit letter/number code we talked about back when we first started beta testing the 6.7? Each injector has its own flow rate code on the injector from Bosch and that code has to be put into the ECM per cylinder it goes into so it will run correctly.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  7. #47
    Oct 2011
    Quote Originally Posted by dansdieselp View Post
    Yep, that is it. Its needed every time you change an injector or swap an ECM.
  8. #48
    Oct 2011
    I have a question about CSP.
    I am building a CAN based transmission controller. I need to detune the engine during the shift to manage clutch torque while shifting.
    How fast does the ECM react to a program change request via a CAN message ?
    Is the CAN messaging protocol for changing programs going to be made public so that I can incorporate it into my controller ?
    Thanks !
  9. #49
    Apr 2012
    These are the ones on the 5.9's
    E3259- Fuel Level, Voltage to Percent Full Conversion (some trucks are WAY out like mine)
    E6500 - Tire Revs Per Mile
    Changing the tire size is the only thing keeping me from selling my XRT as I hate having my speedo out, switching from racing tires to winter tires
  10. #50
    Senior Member Krazeeun's Avatar
    Jan 2012
    Yes please, I have a truck at the local dealership right now because of this issue...
    "I will not keep calm..." -Ryan Milliken
    Hardway Performance
  1. 06-07 5.9L Feature Request List
    By GMPX in forum Cummins 5.9L
    Last Post: January 28th, 2021, 03:51 AM
  2. Feature Request List
    By skneeland in forum Cummins 5.9L
    Last Post: June 13th, 2011, 04:54 PM
  3. New feature request / tell me how to
    By Doc in forum General
    Last Post: October 20th, 2009, 03:57 AM
  4. Feature Request
    By Garry in forum General
    Last Post: August 29th, 2006, 01:34 AM
