Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: 07-09 6.7L Feature Request List
    Nov 2005
    Default 07-09 6.7L Feature Request List
    UPDATED Jan 24, 2011
    This is the official place to request features for the EFILive Cummins tuning.
    As requests are posted this list will be grouped by status.
    In progress
    • MIL / DTC disable list, GM style (including electric fans if possible)
    • Enhanced VGT functions
    Soon to move into development:
    • Transmission tuning.
    • CSP – Cummins Switchable Tuning. Use an EFILive Custom OS to switch tunes on the fly. (Method of implementation - Serial/Hardwire will depend on development)
    Noted, no firm time frame:
    • Custom Scaling of Fuel Level Gauge- read and displays accurate fuel tank levels.
    • MAF Logging - if ECM reports it, it will be added.
    • Injector Trim codes
    Features Dependent on V8 Scan Tool Development
    • DVT controls (V8 Scan Tool feature)
    • BBL
    • Option enables; high idle, fog lights, wheel size. All non ECM functions; will be investigated for complexity when V8 infrastructure is finalised.
    Features Not possible/Not considered at this point
    • Defuel using factory EGT inputs - if not already a factory option, very hard to add.
    • Individual PID selection - GM style - Cummins ECM limitation requires PID Group selections only.
    Needs further investigation:
    • Standalone Alternator - need to investigate if it is possible.
    • EBV (Exhaust Bypass Valve, 'EGR Hot Side Servo' control versus engine speed & EMP (Exhaust Manifold Pressure) - requires further explanation
    • Enable separate tables for TPS 0% and TPS>0% - please explain the intent of this request.
    • CCV filter/sensor - more info needed.
    • Re-writing the ECM with a Custom OS to do things the ECM was not designed for. It is possible, but requires MAJOR work. Need to determine if the effort is worth the time/reward.
    Implemented, or scheduled for next release
    • P0601 - Checksum calculation routine - issue caused by "box tuners" not returning controllers to stock - completed awaiting next release
    • Functionality for racing applications - development functionality completed, awaiting 'customer friendly' software implementation for Beta testing.
    • RPM/Fueling parameters
    Cheers
    Cindy
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Here's a start
    Defuel using the factory EGT inputs (relocated to manifold or left post turbo)
    Serial CSP switching like a Duramax (using edge CTS or something like that)
    Special feature enables (like high idle, Fog with High beams, etc)
    DPF and EGR delete abilities (if that's not covered already in racing applications)
    2010 Dodge QCSB 6.7 Auto
    Tune switching was mentioned in Cindy's post.
    The title says: 07-09 6.7L Feature Request List. For those considering posting idea's in this thread, please, for 07-09 only, the 2010+ computer is vastly different, lets not mention it again.
    Sep 2011
    Post edited and mention removed.
    Sorry, didn't intend to request anything that you weren't focused on yet, wanted those for the 07-09.
    Do you plan to have a serial switching method for the csp tunes already, when released of course?
    Sent from my hacked Kindle using Tapatalk
    Don't suppose there would be anyway to alter a not needed signal, something constant. So for example, the grid heater. Instead of firing the grid heater at a certain interval, one could wire up a NOS solenoid in its place and map it into the tables. just using the grid heater as an example. I'm not sure what you could use, it would need to be something that most of us take off or don't use (post injection? if there's a seperate source you could interupt from the ecm) Anyway. it could be used for more than that. Water/meth injection, etc. Just some sort of out source from the ecm that could be mapped into the tuning, i guess you could trigger it off one of the alt maps. You said no matter how wild. LOL
    Quote Originally Posted by davematthews View Post
    Yes Cindy did, but I can see this is going to end up more like a kid in a candy shop with $50 to spend.....I want one of those, two of them, can you make 6 of those.....
    I will admit that the idea seems far fetched. However, one of the box tuners was developing it at one time. So its not that far out there. Besides, all u had to do was say no.
    Dec 2011
    For starters, outside of performance is fix the OE sending unit, how it reads and displays the fuel level in the tank. Instead of 350 miles from Full to 1/2 tank, and 150 miles from 1/2 to empty, it would be nice to see a correct reading.
    Jan 2012
    EBV (Exhaust Bypass Valve , 'EGR Hot side Servo') control versus engine speed and EMP (exhaust manifold pressure).
    - Enable separate tables for
    TPS 0% and TPS>0%
    Needs to be available for 'racing applications' with DPF disabled.
    Nov 2011
    high idle
    VGT control
    yes please to trans tuning!!
  1. 06-07 5.9L Feature Request List
    By GMPX in forum Cummins 5.9L
    Last Post: January 28th, 2021, 03:51 AM
  2. Feature Request List
    By skneeland in forum Cummins 5.9L
    Last Post: June 13th, 2011, 04:54 PM
  3. New feature request / tell me how to
    By Doc in forum General
    Last Post: October 20th, 2009, 03:57 AM
  4. Feature Request
    By Garry in forum General
    Last Post: August 29th, 2006, 01:34 AM
