Results 1 to 10 of 20
Thread: Speed Limiter E37
    Junior Member Bearce Sr's Avatar
    Sep 2009
    Default Speed Limiter E37
    Hi all, trying 2 set speed limiter 4 120km/h changed H0129 from 180 2 120, also changed H0161 from 132 2 72. still lowest speed is132km/h what else needs changed? TKS Ed
    Yeah, you need to set the Speed Limiter source {H0156} to 'ECM', some vehicles are already set to that, if it is not the ECM does not control the top speed.
    Sep 2009
    Tks, H0156 is set ECM any other ideals?
    I'm not sure Ed, it seems like you have done everything that needs to be done. Of course most of the time people want to remove the limiter, not decrease it, so perhaps there is some other calibrations hidden within the ECM that limits the lowest speed. What OS is the E37 you are working on running?
    Sep 2009
    OS is 12630187 It's my kids car she has lead foot 2 many tickets
    I figured as much
    Jun 2012
    I see this is an old thread, but anyone come up with a solution? Having the same problem with an E37 running 12635399. Have done all the above, and the limiter seems to have no effect.
    This tune shows H0156 as Other Module, but made no difference when it was ECM.
    Spark and Fuel limiter options are also enabled, but also made no difference.
    Engine just keeps on going, right past 111 Kmh
    Jun 2012
    Nobody but Bearce and myself have had this issue?
    Does yours keep going to the 132 KMH limit like the original posters? That might be the key to fixing this on the E37 if that is the case.
    Jun 2012
    Can't say. This is on a fleet vehicle, and if the GPS reports a speed over 73MPH / 117KMH, its a company violation. That's why It so irritating when the programming doesn't work as it should.
  1. E37,E38, E67 Speed Density
    By L31Sleeper in forum E37, E38 & E67 PFI ECM's
    Last Post: July 19th, 2010, 10:06 AM
  2. Speed limiter
    By RichardWebman in forum E37, E38 & E67 PFI ECM's
    Last Post: August 7th, 2009, 04:41 PM
  3. zr1 speed limiter
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: February 1st, 2009, 05:07 PM
  4. Speed Limiter
    By devil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2006, 08:00 PM
