Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: LB7 / LLY Injector assignment dispute
    Default LB7 / LLY Injector assignment dispute
    Hi All,
    For quite some time now we've had people saying the DVT controls for injector shut off's are assigned to the wrong injectors. I've had yet another look at this today, I've come up with an alternative, but somehow we need someone to be able to confirm my table is the correct assignment.
    On the left is what we currently have, on the right is what cylinder number 'might' be the correct assignment.
    If anyone can somehow confirm this on a truck it would be greatly appreciated.
    DVT Name
    Injector #4 = #5
    Injector #8 = #8
    Injector #3 = #1
    Injector #6 = #3
    Injector #5 = #6
    Injector #1 = #2
    Injector #7 = #8
    Injector #2 = #7
    Ross, is this what you came up for the LLY? I just checked my LB7 this week and found that the DVT numbers are correct to witch cylinder is actualy turned off.
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rcr1978 View Post
    Well, I don't know then, why are people contacting us saying it's wrong? On all Duramax's I believe.
    The only one that I have heard that was a problem was LLY, but I don't think anyone has actualy confirmed right or wrong with actual testing other than just swapping parts. I tested the LB7 with a scope. Maybe the problem is the balance rates possibly being reported wrong for what cylinder is witch and not the actual DVT tab?
    04 LB7
    2010 LMM
    2015 LML
    Well, I clearly remember people saying they swapped out good injectors because the injector number they shut down on the DVT's turned out not to be the bad one. I suppose we'll just let this thread run it's course and see what pops up.
    Mar 2009
    It was Ben with his LLY that said he had problems with the wrong injector being shut-off. I can try and go down this week and check my balance rates on my LB7 with EFILIVE and then recheck it with a TECH2 and see if they coincide.
    Jan 2009
    I have a lly and balance rates work fine.
    Mar 2009
    Quote Originally Posted by wilsonck View Post
    They work, but it is in question as to wether or not the injector assignment is correct and if the EFILIVE data is reading teh correct cylinder for the balance rate.
    Jan 2009
    I don't want to argue, but I used the balance rates to change an injector that had bad rates. I had high rates + 7 or 8 on injector 7, changed it out and it was good after that and still is. So it worked fine for me.
    I had tried using the DVT's as well to determine which injector was bad, but that didn't work for me. This is what others found too if I am not mistaken
    Mar 2009
    I went back and reread Ben's post and seen where he said he couldn't get a good read on balance rates so he went to shutting them. I thought he had posted about a high balance rate on that one and that was why he was hutting it off. My bad, I misunderstood his post on it.
  1. Will the LB7 switch work with LLY?
    By LBZoom in forum General (Diesel)
    Last Post: March 26th, 2011, 03:34 PM
  2. LB7/LLY Allison DVT
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: May 11th, 2008, 11:26 AM
  3. lb7 or lly
    By 69camaro5speed in forum General (Diesel)
    Last Post: March 2nd, 2007, 11:06 AM
  4. swap my '02 LB7 for an '04 LLY?
    By jerjoek in forum Duramax LLY
    Last Post: September 19th, 2006, 02:11 PM
