Results 1 to 10 of 12
Thread: 1998 with 2 bar MAP
    Senior Member WicketMike's Avatar
    Nov 2003
    Default 1998 with 2 bar MAP
    I found this thread on ls1tech and it looks like there are some people with 98's and turbos that are running a 2 bar map.
    Has anybody here done it? and how can i get it to work?
    http://www.ls1tech.com/forums/showthread.php?t=443095
    thanks
    98' White TA A4 TSP 231/237 PP Stage II 59cc heads
    401rwhp (unlocked) 1.594 60'-11.60 e.t.-116.98 mph
    98' Sport Gold Metallic TA M6 - 13.39 e.t. Bone Stock
    My Trans Ams
    2006 Chevy Monte Carlo SS 5.3L LS4 (wifes car) stock (for now)
    Nov 2003
    tttttttttttt
    My Trans Ams
    Nov 2003
    nobody with efilive has done this? or can you only do it with hptuners?
    Please advise
    thanks!
    My Trans Ams
    Jan 2005
    According to that thread, you need to call Rick.
    Otherwise, it sounds like they wired up a 2 bar MAP resulting VE table colum headings representing a percentage of the 2 bar MAP's range rather than actuall KPA values.
    You can run the 2bar map, you just need to rescale it so everything is halved, so 100kPa will measure as 50kPa, 200kPa will measure as 100kPa.
    It's not ideal, but years ago we ran 99+ LS1's like that and for the most part it works just fine.
    Lifetime Member SS2win's Avatar
    Feb 2005
    would be real nice if live would allow adjusting the interface to reflect 50% values to match...
    2001 Camaro SS
    EFILive Custom OS3
    Nov 2003
    Quote Originally Posted by GMPX
    how would i go about doing this?
    thanks
    My Trans Ams
    Jun 2004
    If I remember you also have to disable BARO updating. If you dont after a couple starts your whole fuel map goes to crap. I found it a real pain since I can go from 200' to 2000' in an hour and I could never get it right.
    I tried it like 3 years ago, unless there is a new 98 OS hack is out there it didnt work all that well for me but you could waste a lot of time with LS1edit fooling around lol.
    Works fine , turn of baro updating.
    Dont stress about the 1/2 scaling as you are tuning to the scanner , so 50kpa in the scanner is still 50kpa in the maps just its 100kpa in actual pressure.
    Auto VE update and everything works properly , you just need to adjust all the map variables that use kpa by 1/2.
    it is a lot of work but we never used to have the option in the old days - same as the 98 guys have now.
    Nov 2003
    so first i install a 2 bar map, then turn off baro updating and then do autoVE ?
    Can you explain more on how to adjust the map variables?
    thanks for your help
    My Trans Ams
  1. License for a 1998 PCM?
    By SOMhaveit in forum Gen III V8 Specific
    Last Post: May 29th, 2010, 07:30 PM
  2. 1998 k1500 5.0 305
    By JustinD in forum Vortec V6/V8 Specific
    Last Post: May 28th, 2010, 03:03 AM
  3. Need 1998 S-10 4.3 PCM Pinout
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: January 2nd, 2010, 11:02 AM
  4. 1998 WS6, Need some help......
    By Dick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 2nd, 2006, 12:12 AM
