basically stock 2002 camaro ss--long tube headers and catback EFI live tuning software. Trying to tune VE and MAF. I have both maf,s,which one would you use.
This is better asked on somewhere like LS1Tech.com.
(Who don't rate the 85mm SLP maf at all).
First, the resistor should be removed from the SLP MAF.
Then you can run either MAF, but you have to edit the MAF table.
+1 what sSid said.
