Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: V2 won't data log
    Senior Member Quinton's Avatar
    Apr 2013
    Default V2 won't data log
    Any one know why my v2 would log or do anything when it's hooked up to a vehicle? I've tried different vehicles and I get the same error. It used to work but now it doesn't after the update. Here is a pic I've updated everything and it shows I did.
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
    After you flashed in the latest firmware into your V2, did you do BBx Program All...?
    Apr 2013
    How do you do that?
    [/SIGPIC]
    Apr 2013
    Everything that I know of is up to date.
    [/SIGPIC]
    Quote Originally Posted by Quinton View Post
    How do you do that?
    Start V8 S&T, goto BBx, click Open, click downarrow->Program All...
    --> note: you have to do Program All... doing just Program is not sufficient <---
    If it was, then you would not see that LCD screem saying the *.pmm file is incompatible with firmware.
    Apr 2013
    Okay ill check as soon as I get home. Another question I've got a buddy that has the same thing kinda. He also said he has updated everything. This is what his says when he try's to log his truck with the laptop connected.
    [/SIGPIC]
    Apr 2013
    After doing this it won't even let me select a controller now? It stops at this screen now.
    [/SIGPIC]
    Apr 2013
    I selected my control and programmed it but it won't let me watch anything off the v2 like it used to. Like balance rates and all that.
    [/SIGPIC]
    Apr 2013
    I can't find program all on my drop down?
    [/SIGPIC]
  1. Replies: 8
    Last Post: May 19th, 2011, 02:36 AM
  2. How to Data Log?
    By duramax07tmd in forum Diesel
    Last Post: May 13th, 2011, 12:28 PM
  3. Get log data off flashscan?
    By pavetim in forum Black Box Logging
    Last Post: November 23rd, 2010, 11:22 AM
  4. I can no longer log data
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2009, 11:09 AM
  5. Replies: 11
    Last Post: October 20th, 2008, 07:47 AM
