Results 1 to 10 of 10
Thread: Cal-Flash
    Senior Member 2006Cummins's Avatar
    Sep 2011
    Default Cal-Flash
    Are we able to use the cal-flash option yet? I assume it will be a faster way of flashing?
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Lifetime Member AFTERMATH DIESEL's Avatar
    Apr 2011
    I don't believe it's going to be an option on cummins ecm's. I'm sure Ross will chime in but Im pretty sure it's out of efilive's control.
    Aftermath Diesel Service
    888-494-0019
    Chris Klenke
    Cummins beta tester/EfiLive authorized reseller
    2007 5.3L Suburban and a 2015 Ram 2500 that's stuck on a train
    Nov 2010
    Cummins ECM requires a full flash...Ross explained it in beta that we would not be able to cal flash the cummins controller due to the flashing protocols, I believe.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Quote Originally Posted by 2006Cummins View Post
    The replies above are correct, we can't do a partial (cal) flash on the Cummins ECM. The Cummins ECM reflash procedure is 100% controlled by the ECM, that is how Cummins designed the system, unfortunately that means it expects that the programmer will always be flashing the entire ECM, there is just no other way to do it.
    GM is the total opposite (excluding the Bosch ECM's). With GM we are able to upload our own reflash code in to the ECM so WE have 100% control of the process, I wish the Cummins ECM's would allow this. As a comparison (not trying to rub it in, just saying), a 2011 Delphi E39 GM gasser ECM contains 3Mb of flash memory, we are using our own in-house bootloaders to read and write to them. Read time (for 3Mb of data) is just on two minutes, cal only reflash is about 30 seconds. In comparison the 5.9L Cummins ECM only has about 1.5Mb of memory, so half the memory as the E39, but of course nowhere near those read or write times. If we were able to use our own code to reflash the 5.9L ECM we'd be reading them in about 1:30 and reflashing in about 20 seconds, kind of sucks doesn't it.
    I believe FORD ECM's are the same as Cummins in that the programming process is 100% controlled by the ECM, no external bootloader is allowed for reflashing.
    Lifetime Member FUBAR's Avatar
    Feb 2011
    Well phuck a duck...I was hoping there was gonna be so glimmer of hope to develop for this. Oh well.
    06 5.9L, EFILive / Silver Bullet Tuning
    06 LBZ, EFILive
    Send all complaints to Cummins, that is the way the designed the ECM, nothing we can do about it.
    Sep 2011
    Dear Cummins,
    Please make your ecm's more like the duramax ecm's, so that I can more efficiently void my warranty, exceed your engineering parameters, and tamper with emissions components.
    Thanks for the explanation.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Feb 2011
    ^^^^^ lmao
    06 LBZ, EFILive
    Senior Member TexasCummins's Avatar
    Jul 2011
    Seven and a half minute flash times are getting old when I just make small changes.
    Occupy Cummins!
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
    Jan 2012
    So how do the on the fly cummins box tuners change programming, w/o reprogramming? Some form of emulation?
  1. Auto Cal LLY Full Flash
    By bobo in forum AutoCal
    Last Post: March 22nd, 2012, 04:18 PM
  2. Unable to Cal Flash PCM
    By yeller in forum General (Diesel)
    Last Post: March 20th, 2011, 09:41 AM
  3. Out of range cal in a GM flash?
    By MaxPF in forum Allison 5 & 6 Speed
    Last Post: February 27th, 2011, 07:06 AM
  4. BBx Cal Flash?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2011, 11:20 AM
  5. Little help on full and cal flash on DSP tune.
    By Brian1 in forum General (Diesel)
    Last Post: March 15th, 2010, 05:41 AM
