Results 1 to 7 of 7
Thread: Aldl Cable + EFI live + Kadett E
    Jan 2012
    Default Aldl Cable + EFI live + Kadett E
    Hello everybody okay?
    Well recently bought a cable that http://aldlcable.com/sc/details.asp?item=aldlobd1u but I could not make the EFI live answer on that cable.
    I am using this macro http://www.4shared.com/document/9jDe_csL/multec700.html the friend of the forum http://forum.monzeiros.com/viewtopic...728&hilit=efi+ # p230728 did live in his case he used a scheme done manually and it worked. I bought this cable aldl and I want to work but can not.
    Vehicle data
    GM Chevrolet Kadett 1995 Model Year 1996 Brazil.
    Fuel: Petrol
    4-cylinder OHC engine
    Power 1.8 GL
    ALDL diagnostic port pin 12, in post # p230728 http://forum.monzeiros.com/viewtopic...hilit=efi+live is making the same and the same type of ECU.
    If anyone can help me make this work I appreciate it.
    Oh, I apologize for my English but I am Brazilian and not speak English. I used the translator of Goolge.
    Thanks!
    Try unchecking the Max232 echo option.
    Jan 2012
    So this guy I've ever ocpção clear and nothing. I do not know what he did ...
    Quote Originally Posted by todiboa View Post
    I'm sorry, but I do not understand what you wrote.
    Jan 2012
    Sorry Paul.
    I clear this parameter and still did not work.
    I tried to select and deselect the other options but neither EFI Live
    worked
    tanks
    Make sure the COM port being used by the USB cable is the same COM port that you have set up in the EFILive software.
    Jan 2012
    Yes, I left the door of the cable with EFI Live, still did not work ...
    Thank you giving me this help.
    Tanks!
  1. Replies: 10
    Last Post: December 26th, 2011, 08:44 PM
  2. Replies: 2
    Last Post: July 25th, 2011, 07:08 PM
  3. EFILive V4 EVAL and ALDL - USB cable problems.
    By Daniele84 in forum EFILive V4
    Last Post: March 25th, 2011, 12:45 PM
  4. Efi live with autotap cable
    By roughneck427 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 04:15 PM
  5. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
