Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: T43 TCC Desired Slip and Adaptive Pressure
  1. #31
    Dec 2007
    I sent you an Email Ian, did you not get it yet?
    No Ross. Nothing arrived yet. Apologies my email sometimes doesnt work.
  2. #32
    Quote Originally Posted by Patrick G View Post
    Apparently begging and pleading aren't enough. Perhaps bribing is worth a try. Slohawk and Minytrkr are correct, this is really the only table that needs to be added to the trans tuning file to give perfect performance. It couldn't be as daunting a task as figuring out virtual VE (cheers by the way). This looks like a relatively simple table to uncover, but it's absolutely critical to the performance of many, many tunes. Please gentlemen, put some resources to uncovering this one table. It's more critical than you probably realize.
    I just bought HPT like so many to control converter lockup. Friggin sucks for something so small in my eye's.
  3. #33
    Lifetime Member tokymon's Avatar
    Apr 2008
    I agree that it sucks to have to buy other software to adjust one table
    But look at the fact that now you can tune 04 and up ruststains and f150s
    And maybe dodge gas ..... Been waiting four years for this
    Owning both has widend my customer base
    I just charge extra if I have to use both softwares
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
  4. #34
    Apr 2011
    Quote Originally Posted by slowhawk View Post
    I tuned my car with EFItuners
  5. #35
    Should mention for anyone following this thread, the TCC slip tables have been added in the latest public release. You can download it from our main web page.
  6. #36
    May 2011
    Sweet! thanks for the info GMPX!
  7. #37
    Apr 2011
    Can someone explain what this does with my Yank 2800.....Thank you
  8. #38
    May 2011
    Quote Originally Posted by zbadestz View Post
    If you have a problem with TCC lockup going in and out at cruising speed, (a common problem with some aftermarket conveters), These tables will help you sort it out. You can find out if you have the issue by logging tcc slip. It should stay at or near 0 slip when in lockup. If it does not, the tables will need adjustment.
  9. #39
    Apr 2011
    Can you post a screen shot?
  10. #40
    Lifetime Member picnic_george's Avatar
    Jan 2007
    My friend is tuning a 2011 camaro a6 with a 3200 yank converter and this seems to be a big issue. He's using HPT and he wants me to take a look at it. I have never used HPT nor do I know anything about these transmissions. Seems like some of you guys use HPT to tune the transmission for a converter
    Can anyone tell me what tables to look at and adjust? I tune my own car and a couple others with EFIlive but this is over my head for sure. It can't be that difficult(I hope)... I would assume, it's just engagement and line pressure isnt it?
    Thanks for the help
    Kris
  1. T43 Torque Converter Desired Slip
    By Meister in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 9th, 2011, 07:02 AM
  2. Possible TCC Slip/TCC Tuning?
    Last Post: March 29th, 2011, 03:41 AM
  3. TCC Slip when showing fully locked.
    By mhburton in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 28th, 2010, 10:14 AM
  4. DTC P1870 & TCC slip table
    By tblu92 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2007, 01:11 PM
  5. Modifying TCC line pressure.
    By Joel_SS in forum Gen III V8 Specific
    Last Post: December 8th, 2006, 10:40 AM
