Results 1 to 4 of 4
Thread: 1024kb RR with 512kb tune
    Junior Member Mayhem's Avatar
    May 2011
    Default 1024kb RR with 512kb tune
    Hi Guy's
    I have decided to start a new thread instead of hijacking limitedcv8r's thread.
    At first I could not load a 512kb tune to my 1024kb RR which I have now sorted out by holding the Shift & Ctrl when clicking on the download button. I now have a new problem, I have loaded the 512kb tune to the RR but now the vehicle will not start! I have tried 3 different tunes and have had no joy, yet the same tune in the std. ECU works fine. Has anyone else had this problem?
    Lifetime Member N0DIH's Avatar
    Jan 2006
    Probably need to do Security learn. From what I gather the BCM gets the PCM Serial Number and if that has changed, then it won't start unless security is relearned.
    Give it a try.
    Or simply turn off VATS....
    I owned a Ford once, ONCE.......
    Nov 2007
    I believe Shift+Ctrl is only useful if you have removed your RR from the 1024k PCM and installed it in a 512k PCM.
    After all you can't bolt a 512 PCM in a 1024 PCM car or truck.
    Hope this helps.
    -Justin
    May 2011
    I have turned the VATS off, still no joy. I have loaded a 1024kb tune onto the RR and had the truck running. I dont have a 1024kb ECU to use in the vehicle but have the 512kb ECU that I ultimately will be using. It is just such a mission not being able to use the RR for tuning.
  1. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  2. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  3. stuffing a 512kb os in a 1mb os...
    By brokenfly in forum Custom Operating Systems
    Last Post: July 8th, 2007, 03:48 AM
  4. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  5. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
