I'm looking at swapping a 68rfe into a Ford truck along with a Cummins 6.7.
I've gone through the wiring in detail and it looks doable. Fairly easy, actually.
It appears to me that the TCM shifts the transmission. It selects the shift points, operates the clutches, watches the solenoids, etc.
When one loads an EFI Live tune for an automatic truck into the Cummins ECM, does it also load some programming into the TCM ? If not, how does one match the TCM programming to the ECM program ? How do I know that the TCM I'd buy to do this will have the correct programming in it ?
