I'm swapping a Cummins 6.7 into an F350.
I need to use Live EFI to control the engine, to remove security, handle the deletes, etc.
So I bought a very low mileage Cummins 6.7. It arrived without an ECM and without a wiring harness.
It was supposed to be an 09, ie CM2100. According to QuickServe, my engine is model year 2010 and its supposed to have a CM2200 ECM. In the mean time, I have bought a CM2100 ECM from an 08. I checked Quickserve and the part number for the injectors on the 2010 engine is different than the part number for the injectors the engine the CM2100 ECM came from.
It gets better.
I've been deliberating what transmission to use behind the 6.7 for a while now. For a number of reasons, I've settled on the 68RFE, subject to finding a good rebuild kit for one.
On the 08 trucks with CM2100 ECMs, the transmission is controlled by the Powertrain Control Module and nothing else. And the PCM does nothing but control the transmission.
On the 2010 trucks with the CM2200 ECMs, it is my understanding that the transmission is controlled only by the Cummins ECM. This would make swapping a 68RFE into my F350 significantly easier.
So... I have 2 options.
Option #1. Put a CM2100 wiring harness on my 2010 engine and run the CM2100 ECM. Get a PCM to control the 68RFE and wire it up.
Option #2. Put a CM2200 wiring harness on my 2010 engine and buy a CM2200 ECM and sell the CM2100 ECM. I don't need to buy a PCM.
What would you do ? I need this thing running in May or June to pull my trailer. I don't want to pull anything with the 6.4 and 5R110 because I don't trust Ford powertrain stuff.
What is the earliest a CM2200 will be running Live EFI ? What does it take to get on the beta list ?
Thanks !
