Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 112
Thread: Still Working on a "Smokeless" tune....
  1. #101
    Senior Member TexasCummins's Avatar
    Jul 2011
    Quote Originally Posted by Dmaxink View Post
    Texas-for the hell of it, try loading in stock main and pilot timing values and report back...your results may be surprising...
    Will do after all this rain goes away.
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
  2. #102
    Lifetime Member FUBAR's Avatar
    Feb 2011
    I've done it!! I've broken free from my nasty habit of...SMOKING!! After reviewing logs and knowing what values smoke and doesn't smoke, blendind and rounding everything linearly, I now have a "smokeless" tune!! There's a light haze at best building up to 20+psi boost and there is no "wall" where the tune just let's go after building "X" ammount of boost or feels like the truck is holding back when the torque converter is locked in 4th when you want to accelerate. It's now clean and very smooth! Glory Hallelujah!!! Man I'm pumped...
    06 LBZ, EFILive
  3. #103
    Feb 2011
    Attached are a couple pics where the mm3 line takes a similar path as boost is built. VERY similar when the throttle is rolled on and quite similar when mashed. Seems to be key for me in making boost and supressing smoke without feeling limited.
Name:	Pedal Rolled on Boost.JPG
Name:	Mashed Boost.JPG
    06 LBZ, EFILive
  4. #104
    Senior Member 2006Cummins's Avatar
    Sep 2011
    Great work. I'm happy for you!
    On a side note; I have been having a hard time setting up my dashboard like you have done. I have the analog gauge setup on one page, but it is not something that I am very proud of. I know that viewing logs in the format that you are using is a much better way to do it. Has anyone posted a file for the different pages that I can download?
    Made a little more progress with the boost limiter today...
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  5. #105
    Jul 2011
    I changed my pre-2,000rpm timing to a modified stock and it smokes less and only gives a quick, slight haze when you get on it then cleans up. I noticed I'm also getting more 2-3-2-3 shuttling with this change.
    2006 Ram 2500 4x4
  6. #106
    Feb 2011
    Thanks! Right click and change to chart layout. The. Right click once in the chart and click series tab. The. Select whatever PID's you want to view and also you can change the range of the pid, line size, font, label, etc.
    06 LBZ, EFILive
  7. #107
    Lifetime Member 06redram's Avatar
    Jan 2011
    Big Red finally smoke free from stop too wide open with big power also sounds better than the stock OEM tune at idle. It has been months of fighting for the sweet spot😃 I like to thank all for all the tips that has been posted 👍
  8. #108
    Junior Member chance cobb's Avatar
    Jun 2011
    thats goodnews
  9. #109
    Sep 2011
    Ok FUBAR, with all of this talk about how good your truck runs and how little it smokes I had to contact Les at silver bullet tuning. I just started working with him and all I can say is "wow"! I now have zero smoke during normal acceleration, and much less smoke during moderate/heavy accel. I'm surprised how it can be responsive, and clean. I'm one of those guys that likes to do everything myself, but sometimes help from someone who really knows what they are doing makes all the difference. Les obviously knows what he is doing! I'm really excited with the progress that has been made, and to get everything dialed in.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  10. #110
    Feb 2011
    2006Cummins, that's really great to hear! I know exactly what you mean by being a DIY guy when it comes to your truck. But whether it be my truck, or framing a door, if I don't exactly know how to do it, I'm not too proud to ask for help (just ask my buddy who came over a few weeks ago with his portable planer, lol.) Now log, small change, log, small change, etc. I'm actually happy to say I haven't flashed my truck in a while, I'm that happy with it.
    06 LBZ, EFILive
  1. F3-"switchable tunes" not working
    By killerbee in forum General
    Last Post: March 28th, 2011, 04:55 PM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  5. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
