Results 1 to 4 of 4
Thread: The new guy
    Jul 2008
    Default The new guy
    I have a 98 ta just put a cam and heads on. I got the tune form the same person i got the heads and cam . the car runs fine but idle goes up and down. Can u show me where and how to chage the idle setting.thanks
    Aug 2004
    Is it fueling related, spark related or airflow related?
    If airflow, go to your DESIRED AIRFLOW table, and add a percentage to it in the coolant temperature tab you are having an issue with., if it gets better, add more until if is fixed. That is the quick explination, there are more exact ways explained in this forum if you do a search.
    Jul 2008
    Thanks i will try that
    Jul 2008
    It airflow it was tuned with a ported ls6 intake and ported tb. Ihave a stock ls1 intake and tb
  1. New guy
    By jkf in forum General (Diesel)
    Last Post: March 26th, 2011, 03:37 PM
  2. New Guy here
    By corvettebob1 in forum FlashScan V1
    Last Post: December 27th, 2010, 09:50 AM
  3. New guy with 8.1
    By azcagiva in forum Gen III V8 Specific
    Last Post: July 6th, 2010, 02:03 PM
  4. new guy here
    By Doege09Dmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 28th, 2010, 04:55 PM
  5. New Guy with ?'s
    By jmac in forum Duramax LB7
    Last Post: August 2nd, 2009, 01:14 PM
