FYI: Someone is asking the following question...
Also, when is HP Tuner going to include access to the "end injection point" relative to crank position?
Hmm, The mass or fuel injected on the first or second simultaneous, non synchronous, and syncronous, Injection.
Prime and octifire. Too much fun.
I suppose i could build you a cax if you really really need it. It dont seem to be anything that a guy would want to mess with?
Nothing references to Crank position though?
What operating system?
I saw this on LS1Tech in a discussion on injector duty cycles,
so it appears to be F-body or Y-body PCM with stock OS.
http://www.ls1tech.com/forums/showthread.php?t=441394
