Results 1 to 5 of 5
Thread: DTC and MIL Fault Processing tables not accessible in 2010 and up T43s
    Mar 2010
    Default DTC and MIL Fault Processing tables not accessible in 2010 and up T43s
    We are trying to turn off the U0100 MIL/DTC fault processing in a 2010 TCM as well as a 2012 T43 and neither of them allow you to even see the Transmission diagnostics. Is this because the tables changed and EFI Live can no longer access them?
    We tried to force full reflash the 2010 Escalade T43 back to the 2009 *179 operating system since that lets you edit the DTC and MIL stuff and it programmed it but now when reading the tune or scanning it complains about an incomplete operating system.
    Thanks in advance for any ideas on this.
    Jun 2008
    Bump!
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    Aug 2010
    Quote Originally Posted by whypave View Post
    ... We tried to force full reflash the 2010 Escalade T43 back to the 2009 *179 operating system since that lets you edit the DTC and MIL stuff and it programmed it but now when reading the tune or scanning it complains about an incomplete operating system ...
    Hello Whypave,
    The 2007 to 2009 T43 controllers are generally mutual compatible - that is, they may be programmed with 2007 to 2009 OS despite the trans model year. The T43 controller changed in 2010 (except Camaros). A 2010 Escalade T43 is incompatible with a 2009 OS flash - and may be fatal to the controller.
    Regards,
    Taz
    Jun 2008
    The question still remains, why can't we get into the tcm diagnostics?
    -John
    :drivin:
    Because we haven't mapped them out yet.
  1. DTC Processing Enablers?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 25th, 2015, 06:51 AM
  2. MIL P069E Need Help!
    By mirage in forum E37, E38 & E67 PFI ECM's
    Last Post: July 28th, 2011, 02:33 PM
  3. flashing MIL?
    By Thimble in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 01:44 PM
  4. MIL for a LS1 conversion
    By Biggsy in forum Gen III V8 Specific
    Last Post: April 7th, 2007, 05:44 PM
  5. DTC Type A/B/C, MIL Yes/No
    By Teutonic Speedracer in forum General (Petrol, Gas, Ethanol)
    Last Post: February 27th, 2006, 03:58 PM
