Results 1 to 3 of 3
Thread: wiring
    Dec 2005
    Default wiring
    any one know how to find the wiring pin outs from pcm i have one from chilton for the year i have but doesnt match my pcm was wondering if theres a ways to look up pin outs from vin numbers or is there some basic wiring same from pcm to pcm trying to wire up a stand alone wiring harness to dyno
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    What is your engine and what year? If it's an LS1, go here
    http://www.ls2.com/boggs/torques/enginetorques.htm
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Dec 2005
    Default year engine
    i have a 2005 8.1 and a 2001 8.1 putting a twin turbo 582 in a 2005 suburban so i have that pcm and i have a 2001 suburban for parts but i figured there wiring is differant wanting to engine dyno the motor first only dyno i have so i think i need to use the 2005 pcm but like to use the wiring out of the 2001 to dyno with i know sounds crazy thanks for link will check it out
  1. N20 Switch wiring with OS5
    By BowlingSS in forum Custom Operating Systems
    Last Post: August 14th, 2009, 12:50 AM
  2. Plx wiring help
    By blazinblue in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2008, 07:53 PM
  3. 01-02 to 03-04 cpu wiring and programing
    By woody69 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2007, 05:47 AM
  4. LM-1 Wiring and logging
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2007, 04:43 PM
  5. Need Help Wiring up Sm-AFR to V2
    By Chalky in forum General
    Last Post: March 11th, 2007, 05:36 AM
