Results 1 to 2 of 2
Thread: Cleared Codes Now Air bag Light Is Illuminated And ABS Light Comes On When I Hit Bump
    Member ippielb's Avatar
    Jun 2010
    Default Cleared Codes Now Air bag Light Is Illuminated And ABS Light Comes On When I Hit Bump
    So, with it being -40*C here for a while, i had a code come up with my truck, so when i was letting my truck warm up, and i read the codes, it was a knock sensor code, which i knew i had to replace, and i have everything to replace it with, so i just cleared the codes, WITH THE TRUCK RUNNING, and after that, my airbag light decided to come up and stay illuminated.
    What can i do to stop it from being lit up?
    And second, i just re-geared my truck from 3.73, to 4.56, and i went into my tune and changed my gears and tire size to match. 35" tires, and 4.56 gears. Now every time i hit a large bump, or go over rough train tracks, my ABS light comes up, and stays lit up until i turn my truck off, then when i start my truck, it is still illuminated until i drive it for a little bit and then it goes off again, UNTIL i hit another bump or train tracks...
    What could i do to stop this?
    2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    NADP Race Transmission & NAPC Built Transfer Case
    AFE Stg 2 Intake Snow Performance Methanol Injection
    FASS 150gph Titanium Series Pump EFI Live
    PPE Race Valve & PPE Fuel Rail Fitting
    BD Manifold 3" AFE Ceramic Downpipe 4" Straight Pipe
    Yukon Grizzly Locker Mag-Hytec Cover & Traction Bars
    Leveling kit & 33" Hankook RT03 18" XD Addict Rims
    HID's all around LED taillights and 3rd brake light
    Autometer Fuel Pressure, Boost, and Pyro Gauges
    EFIlive can't stop the ABS indicator from lighting... EFILive can clear the code, but if the fault persists the ABS indicator will light again.
  1. ABS/BRAKE light still come on
    By LIL DAVE in forum Tips and tricks
    Last Post: June 7th, 2014, 04:50 AM
  2. my air bag light came on after a tune
    By ace68 in forum Gen III V8 Specific
    Last Post: May 15th, 2011, 10:44 AM
  3. Service brake system w/ABS light and Parking Light on
    By mshirshe in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 13th, 2010, 03:32 AM
  4. HELP Abs light on after speedo recal
    By Madspeed in forum General (Diesel)
    Last Post: June 22nd, 2007, 11:15 PM
