Results 1 to 8 of 8
Thread: Help with DSP5
    Senior Member JustinD's Avatar
    Jul 2009
    Default Help with DSP5
    I am helping a buddy, he bought a DSP5 switch and installed it, I reflashed the truck and all went well, but the tune isn't switching, I opened the scantool and it says 5.01v and never changes when I move the switch?? I looked over all the DSP related folders in my tune and it all looks ok, I did this exact setup in another 03 truck last summer, worked fine??? Could the switch be bad?? I thought I would setup my V2 to use it to switch the tunes and see if that works, then we will know rthe switch is bad. I had him take the ECM plugs out again and double check that the pins are in and the right places, all looks good. I believe he bought the switch from Dmax store. Anyone have any ideas?? I really appreicate the help. Thank you!
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
    Apr 2008
    I would say the pin is in the wrong location. You can use an ohm meter to test the switch. If it changes to the correct resistance based on the pdf file on DSP then the switch is good. Might be best to test to the pins to confirm wire is not broken. Im pretty sure you had only one choice but to make sure you Full Flashed the tune to the ECM.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Jul 2009
    Ok, I'll recheck location and check it with a meter. Thank you.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jul 2009
    Yes I full flashed the ECM to the new custom OS too.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Mar 2009
    Are you SURE that the pins fully seated when you inserted them? Many people forget to pull the lock tab out when they put them in and they will not go in deep enough to contact the ECM pins.
    Jul 2009
    I'm gonna have to check again, he installed the switch, so I'll double check.
    Thanks!!
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jul 2009
    I think your right, never removed the pin lock. Thank you again.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Mar 2009
    Quote Originally Posted by JustinD View Post
    It happens ALOT.
  1. dsp5 help
    By johnj in forum Diesel
    Last Post: February 12th, 2011, 05:31 AM
  2. dsp5
    By iranaround in forum General
    Last Post: July 17th, 2010, 07:23 AM
  3. Dsp5
    By L31Sleeper in forum General (Diesel)
    Last Post: July 8th, 2010, 10:05 AM
  4. Dsp5
    By turbo lcc in forum Duramax LLY
    Last Post: March 17th, 2007, 08:46 AM
