Results 1 to 7 of 7
Thread: Cax file problems
    Junior Member Manbearpig's Avatar
    Dec 2009
    Default Cax file problems
    Doesn't seem like EFI Live is loading up my Cax files
    I have the appropriate file for my OS in the calibrations folder but it doesn't seem like the application is reading it or seeing it..
    Help!
    2003 1500HD Quadrasteer- 6.0/80e|V2
    2004 GMC Sierra- LM7/60e/G80|V2-Totaled :(
    2004 GTO TR- LS1/60e
    Make sure your *.cax file is in the folder:
    \Program Files\EFILive\V7.5\Calibrations (for WinXP and Win2000)
    or
    \Program Files (x86)\EFILive\V7.5\Calibrations (for Vista and Win7)
    The cax filename MUST be the same as the operating system number. So if your *.tun file's OS number is 12345678, then your cax file MUST be called 1234567.cax
    You can get additional trace info by adding a /l (space, forward slash and lowercase L) to the V7 Tune Tool shortcut. Right click the shortcut and select properties and add it to the Target setting).
    The trace info will be saved in the file:
    \Program Files\EFILive\V7.5\Startuplog.txt (for WinXP and Win2000)
    or
    \Program Files (x86)\EFILive\V7.5\Startuplog.txt (for Vista and Win7)
    Don't forget to remove the /l from the shortcut after you have finished with the trace info.
    For example this is part of the trace that gets created on a test system here, i.e. I don't have a cax file so it shows up as not found in the trace:
    13:53:46.963|5512|Opening user cal file "C:\Program Files (x86)\EFILive\V7.5\Calibrations\12604138.cax"
    13:53:46.964|5512|User cal file not found, not loaded.
    Hi MBP, post your cax file here.
    Dec 2009
    I got it to work
    Ended up uninstalling and reinstalling and it started working then
    Ok cool
    Dec 2009
    Thanks for the help anyway!
    May 2010
    +1 for this thread, helped me fix my caxb(12212156) addition to my tune. gonna try out lean cruise after doing a full OS/CAL reflash. Gotta compare a Holden tune to see what it suggests for LC settings.
    Thanks guys
  1. .cax file updates
    By joecar in forum CAX Files
    Last Post: August 14th, 2015, 07:17 AM
  2. Cax file help and possibilities
    By spoolinsteve in forum CAX Files
    Last Post: April 15th, 2010, 10:27 AM
  3. Can a cax file be written for...
    By Sparky8370 in forum CAX Files
    Last Post: September 28th, 2009, 02:06 PM
  4. Allison CAX file(s)
    By Cougar281 in forum CAX Files
    Last Post: April 21st, 2009, 12:43 PM
  5. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 04:00 PM
