Results 1 to 8 of 8
Thread: Units flexibility/preferences
    Jan 2006
    Default Units flexibility/preferences
    I have tried, but cannot see how to do this.
    Example: Is there one preferences setting that lets me display all boost figures in PSI instead of inches mercury? It must be so obvious that I am missing it.
    Custom Tuning Services
    Jan 2004
    Tuner or Scanner?
    Edit: I assume Tuner. Click Edit - Configure Display Units. Find the ID that you wish to change. Right click on it and match up which unit you wish to change. When you are finished, click ok at the bottom.
    Jan 2006
    Thank you for replying. I have done that and it just switches between metric and imperial. In HG to KPa. No psi option I can find. Am I stuck with this?
    Jan 2004
    Quote Originally Posted by killerbee
    I'll let Paul or Ross chime in on this.
    We are changing all the units for Duramax to default to PSI, seems that is what the Duramax guys want.....that will be in the next public downloadable update.
    Jan 2006
    Thank you for the replies. Are all tunes created today, backward compatable with future versions?
    Yes,
    EFILive Reseller
    Nov 2005
    As long as we have selectivity...
    Quote Originally Posted by GMPX
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
  1. Changing units with 7.5?
    By PRAY in forum Gen III V8 Specific
    Last Post: September 22nd, 2008, 01:15 AM
  2. How to change units?
    By Lextech in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2008, 10:22 AM
  3. Which MAP Units do you prefer?
    By Blacky in forum Lounge
    Last Post: May 1st, 2007, 07:01 PM
