I have tried, but cannot see how to do this.
Example: Is there one preferences setting that lets me display all boost figures in PSI instead of inches mercury? It must be so obvious that I am missing it.
Custom Tuning Services
Tuner or Scanner?
Edit: I assume Tuner. Click Edit - Configure Display Units. Find the ID that you wish to change. Right click on it and match up which unit you wish to change. When you are finished, click ok at the bottom.
Thank you for replying. I have done that and it just switches between metric and imperial. In HG to KPa. No psi option I can find. Am I stuck with this?
I'll let Paul or Ross chime in on this.Originally Posted by killerbee
We are changing all the units for Duramax to default to PSI, seems that is what the Duramax guys want.....that will be in the next public downloadable update.
As long as we have selectivity...
Originally Posted by GMPX
www.kennedydiesel.com
Specializing in Duramax Performance
More than just a salesman-I use and test the products that I sell on a daily basis.
Superflow Lie Detector in house
Thank you for the replies. Are all tunes created today, backward compatable with future versions?
Yes,
