Results 1 to 5 of 5
Thread: 6l80 won't go into 6th gear above 75mph or so in tap shift mode
    Mar 2010
    Default 6l80 won't go into 6th gear above 75mph or so in tap shift mode
    I have two 6l80s setup with a 2009 corvette OS/tune and setup for tap shifting. gears 1-5 work fine but the transmission won't go into 6th gear via tap shifting over 75mph. We have already adjusted the TU/TD table to not safety shift up or down until you hit a super high mph or a super low mph respectively to allow more complete manual control(off road race buggy not a car)
    but is there some other safety shift table we can't access that is still locking out 6th gear from tap shifting at some point? certainly the normal shift tables allow for sixth gear at much higher speeds.
    Thanks!
    Mar 2010
Name:	why tap shifting may auto shift at WOT table 2.jpg
ID:	12627Click image for larger version.
Name:	why tap shifting may auto shift at WOT.jpg
    Could these settings in the WOT shift speed and WOT shift RPM tables be causing problems?
    no. those settings ownt. attach your tcm tune here as its abound to be something else.
    Mar 2010
    2009_Vette_5.ctd Here is the latest version of our tune. I think the VSS and gear settings may be off but the folks working locally on this in Kansas say the speed from the buggy and the gps speed matched up with these settings. The buggy has 40" tires and 5.40 gears and then the tcase is in 2:1 low range. in the main TU/TD table they put the forced up shifts to the max of 318mph and the forced downshifts to 5mph so they get the closest to full manual control. but even with this the trans won't go into 6th gear above 75 mph.
    Thanks for looking!
    May 2009
    Not sure if you figured out prob yet, but I saw your WOT gear upshift and downshift speeds weren't matching up correctly. Made adjustments that should work.
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
  1. Camaro L99 with T43 5th/6th gear problem at 230 km/h
    By horst in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 20th, 2019, 08:09 AM
  2. 2010 Camaro 6L80 desired shift times
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 05:26 AM
  3. Faster Tap Shift Response
    By duramaximizer in forum Allison 5 & 6 Speed
    Last Post: January 22nd, 2010, 08:24 PM
  4. possible to unlock 6th & 7th gear on older allison?
    By rubbersidedown in forum Allison 5 & 6 Speed
    Last Post: March 18th, 2009, 04:16 PM
  5. Tranny Swap Now No Cruise Control In 6th Gear???
    By Southern Speed in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2007, 03:07 PM
