Results 1 to 10 of 10
Thread: 2009 5500 Duramax idle question
    Senior Member JustinD's Avatar
    Jul 2009
    Default 2009 5500 Duramax idle question
    I have an 09 5500 with an LMM, it idles for 10 mins or so and then automatically shuts off, can I change that with EFI? Also can I just flash it to a stock LMM 2500HD file? Would like a little more power but don't want to hurt it. Hopefully I can disable the idle shutoff with my EFI????
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
    Jul 2009
    I read the truck, it uses the same 8594 OS as some of the other 07+ trucks I've seen. It has a PTO output, and an exhaust brake, so just a reflash to a 2500HD OS wouldn't include those things right? Thanks for any input.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Apr 2008
    I am not sure on the tuning of the medium duty trucks but it can be done. You mean you start the truck with the key and if left to idle for 10 minutes it shutsoff on its own with the key still in and on?
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Jul 2009
    Yes, it has a feature where if you let it idle without the PTO engaged or without your foot on the brake pedal it will shut itself off.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jan 2006
    That is odd. At first it sounded like a remote start safety feature.
    Does it have a factory dpf?
    Custom Tuning Services
    Jul 2009
    Yes it has a DPF, he wanted to delete it with a delete pipe but I think I talked him out of it for now, I'd still like to disable that idle feature though, I was also thnking that I could flash it to a stock LMM 2500HD file, would that be ok? I figured he'd have a little more power but not goning to kill it??? What do you think?
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jan 2006
    I am just making a guess here, as I have scant knowledge of newer MD features. Are there any codes? Is it possible that it is happening because a regen is not progressing on schedule? Regen will not proceed effectively at idle, not enough EGT can be produced
    Jul 2009
    Hmmm, no codes. I did read about someone disabling it with a Tech II on his truck though, it has a button on the dash that forces a regen too, it works. Truck has 17k on it basically like new.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jan 2006
    It would be interesting to see if it changes with a LD file.
    Jul 2009
    I may just have to try it, worse case I can just put it back.
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
  1. 2009 duramax tcm tuning release?
    By 09duramax in forum Allison 5 & 6 Speed
    Last Post: January 3rd, 2012, 05:55 PM
  2. stock duramax rough idle
    By hutch in forum Duramax LLY
    Last Post: April 19th, 2011, 03:56 PM
  3. GM C4500/5500 series PTO Idle control
    By bercar in forum Petrol / Gas
    Last Post: August 28th, 2010, 04:20 AM
  4. 2009 duramax tcm tuning
    By dgdyno in forum Allison 5 & 6 Speed
    Last Post: June 1st, 2010, 03:56 AM
  5. Question on the new december 2009 release.
    By Brian1 in forum Allison 5 & 6 Speed
    Last Post: December 18th, 2009, 05:48 PM
