Results 11 to 20 of 23
Thread: 06 gto ls2 swap in a 93 nissan 240sx motor cranks but wont fire up
    Unfortunately if Ross doesnt know and no one else on the forum has replied, then you might be SOL on it. I have only read an E40 before and never got around to tuning it, plus it was a stock truck and not a swap. Swaps are tricky in this regard, just because the harness and ECM are setup correctly doesnt mean one other tiny thing isnt off. So you get fuel pressure, just no spark when cranking? To me that sounds like a VATS problem...but then again I might be wrong.
    In addition to disabling VATS, you also need to apply the Disable VATS Patch in the OS then full flash the ECM. I dont know if your tuner did that or not, E40/38/67/etc need this done as well as changing the VATS type plus turning the VATS off, its not like the LS1 where you just turn it off and flash it.
    Feb 2012
    That sounds right can u do that with Hp tuners or only efi live?
    Quote Originally Posted by doubledip View Post
    Really??? When you say later do you mean e38's in general or a particular os?
    When the ECM wants to kill the engine if VATS fails, the ECM internally flags injector cut, spark disable and starter disable.
    Quote Originally Posted by awd2ks4 View Post
    No sure about HP, but EFILive can certainly kill off the theft.
    Senior Member doubledip's Avatar
    May 2008
    hmmm ok .. only thought they killed injectors... well the last time i was checking it i was sure i still had spark butno injector pulse... anyway lets move on..
    the most common cause i see for conversions not starting (assuming vats has been turned off correctly) is the wiring of the ignition circuit.. alot of the time people wire the ignition into the ignition circuit that loses power on crank.. best way to make sure this is not the case is any battery power for your loom and ignition power is wired directly to a Battery source (for testing purposes only) this will ensure that not only on ignition on but on cranking there is 12v where its meant to be...
    dont know how many times i have had people assure me over the phone that it has igniton power and i suggest this method and they end up ringing back saying it started after doing this...
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Feb 2012
    Well the guy I had do the harness does a lot of the formula d cars so he can do ls wiring in his sleep. Ill keep the thread updated when I figure it out.
    May 2008
    yes but its not the LS wiring that is the issue.. it will be the mating of it to the car that i was suggesting...
    only trying to help...
    if you take that route of thinking that cause he does formula d cars he can do the wiring in his sleep and i am sure there would be plenty that would vouch for texas speed doing hundreds of LS PCM's that they could do vats in their sleep that it isnt leaving much that could go wrong now
    once again was only trying to help good luck
    E40's hate 'em
    Feb 2012
    Yeah I gotcha and appreciate it alot. That's really the only wiring that was modified on the harness its all plug and play in addition to the Dakota digital for the speedo. If that were the case wouldn't I lose power to the coils or injectors?
    May 2008
    all depends onhow it has been wired.. thats why with the harnesses we do i tell the customer to power the ignition up with battery (only 1 ign trigger wire in our harnesses)
    i dont know how many wires are in your harness that has been made it may cut the coils, injectors , ecu etc...
    E40's hate 'em
  9. #19
    Feb 2012
    Well I guess we will see what happens the pcm will get to tsp on weds
  10. #20
    May 2008
    cool... for your sake/sanity i hope it is something simple like vats not turned off... at least will be an easy fix
    E40's hate 'em
  1. 06 Turbo LL8 Motor swap into a 240sx Preswap questions.
    By All4bspinnin in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 3rd, 2010, 05:01 PM
  2. Cold Start Help....240sx swap transvestite!!!!
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2010, 01:21 PM
  3. motor swap
    By OrangeFlash05 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 4th, 2009, 07:53 AM
  4. CL-Fault after motor swap...HELP!!
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2007, 07:47 AM
  5. LS2 GTO L92/L76 swap
    By robo1 in forum Gen IV V8 Specific
    Last Post: April 14th, 2007, 05:59 PM
