Results 1 to 10 of 13
Thread: E39 DMA PID's
    Jul 2007
    Default E39 DMA PID's
    I've been doing some logging on a late 2011 E39 SIDI and most of it is going well. However, if I attempt to log any DMA PID, the PID Nazi comes along and says "No PID's for you.... Now get out!"
    So, am I correct in assuming that the DMA PID's are OS / Calibration specific and until I get a valid calibration for the OS, I can't log DMA PID's?
    Simon.
    Dec 2007
    Quote Originally Posted by swingtan View Post
    Simon.
    Recall Ross saying some time back they were OS specific, and hard to find. Somewhere in RAM however big that is.
    Jul 2007
    Yeah, I was pretty sue this was the case. I've got the T43 cal after upgrading to RC8 ( which seems to be going well so far ), just waiting on the E39 cal to be done.
    Yeah, DMA PID's have to be defined per OS, it's one of those arduous tasks. They work ok on my E39
    Have you logged knock yet?
    Jul 2007
    Logged knock.......... It's a great saw tooth wave generator.......
    For the life of me I cannot imagine why they were calibrated like that, surely Holden knew 99% of people are going to run these engines on 10cents per litre off low grade supermarket chain fuel.
    Try the same thing on E85, zero knock, it's just a shame the fuel economy suffers so much.
    Dec 2007
    They really have continuous low level knock?
    What sort of consumption on E85 relative to the supermarket dregs?
    Ian, I set my V2 to trigger a beep on 3+ degrees of knock retard, it was unplugged within about 800 meters due to extreme activity, they are that bad.
    E85 around town, fuel econ will jump to about 15.5 - 16L/100. Do the maths at only 20cents per litre cheaper and it's not worth it (as it normall gets low 12's). Plus I need to drive about 10Km to get it.
    Dec 2007
    LOL - you could get the V2 to play a tune on the knock . That's 3+ degrees of knock continuously. I get lots less on 11.7:1 and E10. SIDI motor has more comp I would guess.
    Well at 45%+ more fuel flow at stoich, 16L/100k is not so bad. Only a ~30% consumption penalty. If the price was in the right place it would be worth it . Only time it really works is when 98 is at the weekly high (if one needs 98 that is) - even then its line ball so only benefit is knock and reduced HC's.
    Maybe all the extra money from the Carbon Tax Canberra now has (because they are so serious about the environment), they could throw some more subsidies at E85.
  1. Auto ve for e39
    By redonetoo in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 20th, 2011, 10:15 PM
  2. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  3. inlet valve temp - dma pid not working
    By hymey in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2008, 12:37 PM
  4. DMA Pid trouble
    By MoTruck in forum General
    Last Post: December 29th, 2006, 11:47 AM
