Results 11 to 20 of 23
Thread: COS#3 ... Max MAP = 105kpa in the scanner?
  1. #11
    Jun 2005
    Hehe yeah I guess the data isn't much good if its all zero due to the engine stalling out ;P
    I'll try to get that log made tomorrow after work and emailed. Thanks again for taking a look.
    Hello, my name is Erik and I am a horsepower addict...
  2. #12
    Jun 2005
    Well, logging with the reduced pids and on fast-stream eliminated the problem and I now see higher kPas.
    Still wanna look at the logs Ross?
  3. #13
    Quote Originally Posted by turboberserker
    No, it's all good, now go have some fun :-)
    Just remember to try to keep the PID count under 24 channels.
  4. #14
    Ross,
    Is each PID considered a channel?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  5. #15
    Some take 1, some take 2, some take 0 !.
    If you look at the colum in the PID selection called 'Channels' that will tell you how many channels each PID takes.
    Also, down the bottom of the screen will be some text that says "Selected channels 24 of 96 maximum" , as you add / remove PID's that shows you the amount of channels taken up.
  6. #16
    Lifetime Member MN C5's Avatar
    Mar 2005
    Erik, I just hit the same wall. Did a little logging and at low boost KPA stopped at 105... I'm only using 21 channels, did you change anything else to get it to work?
    I just changed my BEN table to match the Main VE and created a second (Efi map) for the BEN under boosted VE. I orignally combine both the main and boosted ve KPA values onto a single (efi map) because it seemed to make sense.
    Also does anyone know why PID GM.BOOST comes up "is not a valid PID"
    Damnations,,,,
  7. #17
    Jun 2005
    Are you running in Stream-Fast mode?
    Also, as I understand it, the only pid that will work is SAE.MAP.
    I have very pids going -- the bare minimum for autotuning. I have one large BEN table with both VE maps in it.
  8. #18
    Quote Originally Posted by MN C5
    Damnations,,,,
    Without looking, I would guess its a Duramax Turbo Diesel PID - not available on gas engines as gas engines (LS1/LS6) did not come with factory turbos.
    You should use SAE.MAP to see the MAP on gas engines using our 2-3 bar custom OS.
    To see the actual boost you could create a calculated PID that uses the expression: {SAE.MAP} - {GM.BARO}
  9. #19
    Mar 2005
    Looking up fast stream mode right now.... Yes its set to Stream-Fast...
    I'm going to run around the block after changing my boost VE values to 5's and see if it is referencing the Boost VE table..
    Be back in 10
  10. #20
    Jun 2005
    Dennis, either that's one heck of a block, or you got side tracked
    What's the verdict brotha?
  1. Can't read above 105kpa whilst scanning etc
    By ls1vt209 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 30th, 2008, 09:49 PM
  2. NE1: WTF Scanner keeps asking for more Fuel
    By Chalky in forum General
    Last Post: September 23rd, 2007, 08:22 AM
  3. Scanner help
    By wickedred in forum General (Petrol, Gas, Ethanol)
    Last Post: June 22nd, 2007, 11:10 AM
  4. upgrading from V6 to V7 - Scanner only -
    By Blackbird in forum General (Petrol, Gas, Ethanol)
    Last Post: March 24th, 2005, 10:02 AM
