Results 1 to 10 of 13
Thread: CPS relearn
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Default CPS relearn
    I got to the controller, and the "activate" I don't see a learning sub tab where I can click "CASE"
    E38 2007 corvette
    Idling in drive way now.
    Elmer
    Apr 2004
    I see
    exhaust cam phase solenoid bank 1
    exhaust cam phase solenoid bank 2
    intake cam phase solenoid bank 1
    intake cam phase solenoid bank 2
    Right colimn
    4 blocks for degrees with all of them showing 0 degrees
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Apr 2008
    You mean an option next to the CASE like in the others you mention correct. Not just the CASE under the ECM Setup.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Apr 2004
    Well while sitting here, I went into the ECM setup tab and found C.A.S.E.
    Is that what you guys were referring to?
    DVT - ECM Setup - Activate - CASE - 4000 roms - stumble, idle down - turn off engine - click deactivate
    With possibly having my foot on the brake?
    Apr 2004
    Yes that is where I found it. So I can do the relearn with the above instructions?
    Apr 2008
    Ok good you have it figured out.
    Brian
    Apr 2004
    Did it twice. Did not fix my issue.
    Thanks for responding
    Elmer
    Jul 2007
    What's the problem ?
    Apr 2004
    http://forums.corvetteforum.com/c6-f...h-e-force.html Long and challenging. Best improvement so far was new 65 FAST injectors. I'm having high boost and KR now that I'm running the new replacement SC. We're looking to check the CATs to see if I'm plugged. I have a larger SC pulley in hand to pull back on the boost of the CATs are clear. I'm putting on LG hEaders this week too. Sigh...
    Elmer
    Apr 2004
    Here too but this refers back to the same big thread on the corvette forum http://forum.efilive.com/showthread....ing&highlight=
  1. Cant do a relearn
    By nonnieselman in forum FlashScan V2
    Last Post: September 4th, 2012, 02:27 PM
  2. Cant perform relearn..help
    By slow89irocz in forum FlashScan V1
    Last Post: October 16th, 2008, 03:08 PM
  3. cant perform relearn
    By slow89irocz in forum Gen III V8 Specific
    Last Post: October 16th, 2008, 02:51 PM
  4. crank relearn
    Last Post: August 28th, 2008, 06:07 AM
  5. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
