Results 1 to 10 of 14
Thread: 4L80E downshift firmness question
    Senior Member Wolfie's Avatar
    Dec 2007
    Default 4L80E downshift firmness question
    Did search, but can't find what I am trying to look for...
    07 Express 2500.
    When manually downshifting, is there somewhere to look to make the downshift happen quicker?
    When downshifting from 3 > 2 or 2 > 1 it seems to take way too long to make the downshift.
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
    Aug 2010
    Hello Wolfie,
    Take a look at your settings for:
    • D0928 (Manual downshift 2>1 shift speed)
    • D0933 (Manual downshift 3>2 shift speed)
    • D2003 (Abuse mode speed enable)
    Regards,
    Taz
    Dec 2007
    (I hope this works, I'm sending this from my iPhone while at work)
    Thanks Taz, but that's not what I mean.
    I have the tranny shifting when I want it , in part to a trans tune from a hummer.
    I mean the time from when the downshift begins, and when it is fully downshifted.
    Almost like a slipping tranny on an up shift.
    Wolfie
    Aug 2010
    OK .. now I understand ... my apologies for my confusion.
    No direct parameter in the calibration that comes to mind for manual downshift times. If you are manually downshifting at low % TPS or while coasting - the TC will be unlocked in a truck tune -and this will make the shift feel longer. At high % TPS or WOT the manual downshift should be quicker.
    I generally use TransGo kits in 4L60 and 4L80 - haven't tuned a stock 4L80 in a while. Nothing comparable here right now to log.
    Regards,
    Taz
    Dec 2008
    This seems to be one of the few tables "The other guys" have, but is not in EFILive. The table is called "Brake shift pressure vs Torque vs Gear". It looks backwards from a normal shift pressure table (low torque input is high pressure) because the transmission is mostly only de-applying clutches. Yes, the overruns and bands get applied sequentially, but these aren't important to operation, as they only keep the engine from over-running the transmission, they aren't really holding any power.
    Dec 2007
    sigh..... ok.... thanks for the answers...
    Wolfie
    Quote Originally Posted by slow67 View Post
    When I get a chance I'll ask Ross/Paul if this can be made available.
    Dec 2007
    Thanks Joe!
    Wolfie
    Dec 2008
    X2!
    I'll be honest guys, I just don't know when I can go back and look at the T42 stuff again, I mean, I'll put it on my list, but that list is very big.
  1. did segment swap to 4l80e have a question
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 3rd, 2011, 11:42 AM
  2. Built 4l60 w/Transgo shift firmness
    By InTruckDesign in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 30th, 2010, 01:33 PM
  3. Decel Downshift
    By L31Sleeper in forum CAX Files
    Last Post: February 21st, 2010, 02:45 PM
  4. 4l80e question
    By aaronr in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 19th, 2009, 05:44 PM
  5. a4 shift firmness?
    By ls698ta in forum Gen III V8 Specific
    Last Post: May 22nd, 2008, 01:12 PM
