So far...ZERO failed BBF (usually every 3 or so)on Cummins controller...and I think it actually flashes faster now than before.
Great work guys!!!
Great work guys!!!
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
Thanks Les, because that makes sense for Cummins. Send the data slower and it flashes faster
I updated to this release today after a couple of weird issues with the firmware in RC8. I'd paused a log file and when restating, the timer came back to life and the PID data started updating, but the frame count didn't increase. When I canceled the BBL session after driving for 20min, the log ended at shortly after the car had previouly been stopped, so nothing was written to the SD card after waking up the V2. The steps involved were...
- Start a new logging session.
- Drive for 20 min or so, the frame count going up all the time.
- Stop the car and get out, the V2 was left alone as it has the 60 sleep timer set.
- Come back to the car after 10 min or so.
- Turn ignition on, pick yup the V2 ( which has gone to sleep and has a blank screen ).
- Press the <OK> or <Power> buttons to wake up the V2. Normally I just watched to see the timer start and/or the PID data on the screen change.
- Drive another 15 to 20 min.
- Turn off the engine and press the <Cancel> button to finalise the log.
At step 8 I notice the frame count was way lower than I'd expected and before I canceled the log, I noticed the frame count was not increasing, even though the timer was. So after finalising the log, I saved a trace file just in case. I'd almost think that the routine to write data to the SD card never came back, as everything else seemed fine. If you want the trace file, let me know.
I'll also retry this with the latest firmware to see if it re-occurs.
Simon.
When the log is paused, the timer will increment but the frame count will not - just like you described.
Pressing the OK button during a log will pause the log. Not sure what the ramifications are of pressing the OK button to wake from sleep during a logging session - I'll need to test that.
FlashScan should ignore any button used to wake from sleep, but maybe it is processing the OK and pausing the log.
OK, maybe that's what I did. I've paused logs a few times and only had this occur post RC8. I tried to replicate this morning on RC9 and it didn't occur, maybe the "key debounce" wasn't working correctly before and it picked up multiple key presses, putting the V2 into "pause" mode? Anyway, I'll keep testing.
simon
Any updates on when the release of the stable RC10 system is going to happen for Cummins 6.7 tuning?
I upgraded by blue V2 the other day but I'm worried about using a pre-release (RC9) program to tune a 6.7 Cummins.
I just updated the V8 and V7.5 to RC9, the bootblock to 2.07.04 (Dec.12 2011), and the firmware to 2.07.23 (Feb. 12, 2012). This was done without uninstalling anything first. Now, when I try to flash with the V2, it says something about the firmware not being correct, and will not flash. Any ideas what is wrong?
Thanks,
Mike
2019 Ram 6.7L 68RFE
2003 VW Jetta TDI
Hi Mike,
Are you trying to BBF from the V2...?
If so, did you run the V8 S&T software, go into BBx and Program the files into your V2 (you may have to format the Config space first)...?
