Yes, I am trying to BBF. I have not run the V8 scan & tune and programed the files into the V2 since it has been updated. When I click on the BBX tab, then on tune, all of the captions say "unused." I think I remember seeing a CMB option in there before. Does the V2 need new config files with the updated RC9?Hi Mike,
Are you trying to BBF from the V2...?
If so, did you run the V8 S&T software, go into BBx and Program the files into your V2 (you may have to format the Config space first)...?
I thought I read that with this version EFI did not have to be uninstalled to be updated - maybe I have it backwards. I updated from the previous version - can't remember what that was off hand.You may have to uninstall EFI and reinstall. I beleive they said that a new installer was being used and you had to uninstall the software first and then install. What version did you upgrade from?
